**Control-Freak Components Overview** ### Summary ##### Control Freak Components - The ***[IDE (Authoring Software)](Components/IDE)*** enables authoring of *Control-Applications* as well integrating of devices and third party services and plugins. - The ***Control Application*** represents the final interface to devices and is usually a one-page web-application, running in all modern browsers and devices. - The ***Control-Freak-Server*** is a *command line application*(or *background-service*) which connects devices or services with the *IDE* or *Control-Application* - ***Devices*** are any devices which can be controlled over network. - ***Adapters*** enable access to 3th party services, products and platforms. ##### Third-Party Software & Projects - The ***OpenHab*** adapter enables direct access to hundreds of devices types. - The ***MQTT*** adapter also enables access to the many services and devices - Finally, the ***Nodes-JS Package*** adapter enables access to any Node-JS package. Most new implementations can be found at [www.npmjs.com](www.npmjs.com)
