control-freak-ide/Control-Freak-Documentation/docFiles/internal/07_Components/_index.md
1.2 KiB
Control-Freak Components Overview
Summary
Control Freak Components
  • The IDE (Authoring Software) enables authoring of Control-Applications as well integrating of devices and third party services and plugins.
  • The Control Application represents the final interface to devices and is usually a one-page web-application, running in all modern browsers and devices.
  • The Control-Freak-Server is a command line application(or background-service) which connects devices or services with the IDE or Control-Application
  • Devices are any devices which can be controlled over network.
  • Adapters enable access to 3th party services, products and platforms.
DeviceServer
Third-Party Software & Projects
  • The OpenHab adapter enables direct access to hundreds of devices types.
  • The MQTT adapter also enables access to the many services and devices
  • Finally, the Nodes-JS Package adapter enables access to any Node-JS package. Most new implementations can be found at www.npmjs.com
