control-freak-ide/documentation/docFiles/internal/01_Interface/_Keyboard.md
2.3 KiB
Keyboard and mouse controls
File Actions
  • F1 : Help
  • F2 : Rename
  • F3 : Preview file
  • F4 / Enter : Edit file
  • F5 : Copy to
  • F6 : Move to
  • F7 : Create directory
  • F8 / Delete : Delete
  • F9 : Create file
Editor
  • CTRL + F11 : Maximize Toggle
  • CTRL + S : Save
  • CTRL + F : Open search
  • CTRL + L : Reload
  • Ctrl-F / Cmd-F : Start searching
  • Ctrl-G / Cmd-G : Find next
  • Ctrl -/ + : Change Font Size
  • SHIFT + CTRL-G / SHIFT-Cmd-G : Find previous
  • SHIFT-Ctrl-F / Cmd-Option-F : Replace
  • SHIFT-Ctrl-R / SHIFT-Cmd-Option-F : Replace all
  • F1: Open - Help and more Keyboard shortcuts
Clipboard
  • CTRL + C : Copy selection to clipboard
  • CTRL + X : Cut selection to clipboard
  • CTRL + V : Paste selection
Navigation
  • Enter : Open or edit folder or file
  • ALT + ENTER : Open in new tab
  • BACKSPACE : Go back in history
  • ALT + 1 - 10: Choose Source
Window & Panels
  • CTRL + W : Close current tab
  • F11 : Browser fullscreen
  • ALT + F11 : Toggle navigation panel (if exists)
  • CTRL + F11 : Toggle navigation panel and ribbon, (if exists)
  • NUM + + : Num & Plus selects next tab
  • NUM + - : Num & Minus/Subtract selects prev. tab
  • CTRL + F1 : List mode
  • CTRL + F2 : Thumb mode
  • CTRL + F3 : Tree mode
Tree
  • Left : Collapse/Expand folder
  • Right : Expand folder, if open, go into!
  • Home & and End as usual
Selection
  • SHIFT+UP/DOWN : Multi-Selection, hold CTRL and release SHIFT to skip next whilst pressing up or down
  • CTRL+A : Select all
  • CTRL-D : Select none
  • CTRL-I : Inverse
  • CTRL + CLICK : Append/add to selection
  • HOME : Go to first row : works with SHIFT
  • END : Go to last row : works with SHIFT
Mouse
  • Right-Click : Open context menu
  • CTRL : Enable copy mode for drag and drop
  • Uploads : Simple drag files from your desktop into any file panel (uploads go over XHR, so adjust post size!)
  • Remote downloads: drag the browser url into any file panel
Console & Terminal
  • CTRL + Enter : Send or run selected text
  • SHIFT + Enter : Clear output
