2.4 KiB
Usage
Windows
- Drag your user folder (MyUser\Documents\Control-Freak) onto Control-Freak\export.bat
Linux/OSX
run ./Control-Freak/export.sh --user=MyUser/Documents/Control-Freak
wait til terminal closes (may last up to 5 minutes)
your exported app is located at /exported (will be overridden the next time)
run /exported/start.bat (linux/osx: start.sh)
run /exported/stop_servers.bat (linux/osx: stop_servers.sh) to shutdown the app (important if you export the second time) on a non IDE computer, otherwise press CTRL-C in the existing running server terminal window
Data & Servers
web-server : runs at 8889, so you open this url: http://localhost:8889/
your workspace, located then at http://localhost:8889/user/workspace. You must open the files with *.html extension, not *.dhtml
devices : all tagged with "Run Server-Side". The device server tries connecting/re-connecting every 3 secs
drivers : no modification
device-server: runs at 9997
database-server: runs at 27018 (Mongo)
mqtt-server: 1884 (Mosca)
More options:
The export script (export.bat or export.sh) sets only default options. It basically goes in the server directory and runs:
./server noob --client="../../Code/client/" --file=export.js --system="../../data" --user="$1" --target="../../exported" --dist="../../server/" "$@"
You see that it is using the first argument to specific the source location of your default user workspace (Documents\Control-Freak).
Options:
-h, --help output usage information
-V, --version output the version number
-f, --file <path> run a file
-r, --root <path> root path to Control-Freak
-u, --user <path> user directory
-t, --target <path> target directory
-s, --system <name> path to system scope location
-d, --dist <path> path to the pre-compiled NodeJS servers
--windows <boolean> true/false to export windows NodeJS server
--osx <boolean> true/false to export OSX NodeJS server
--linux32 <boolean> true/false to export Linux-32 Bit NodeJS server
--linux64 <boolean> true/false to export Linux-64 NodeJS server
--arm <boolean> true/false to export ARM-v7 NodeJS server
--client <string> path to client root
The more interesting option is --target. It specifies where to export your application.
