machines/howtos/cut-out-shapes-out-of-plastic-sheets-with-a-cnc-
1.jpg init 2023-11-12 21:43:05 +01:00
2.jpg init 2023-11-12 21:43:05 +01:00
3.jpg init 2023-11-12 21:43:05 +01:00
4.jpg init 2023-11-12 21:43:05 +01:00
5.jpg init 2023-11-12 21:43:05 +01:00
6.jpg init 2023-11-12 21:43:05 +01:00
7.jpg init 2023-11-12 21:43:05 +01:00
8.jpg init 2023-11-12 21:43:05 +01:00
9.jpg init 2023-11-12 21:43:05 +01:00
choosing-a-file-to-cut-.md howto llm test 2025-03-27 15:02:04 +01:00
cut-out-shapes-out-of-plastic-sheets-with-a-cnc-.md howto llm test 2025-03-27 15:02:04 +01:00
follow-the-cutting-wizzard.md howto llm test 2025-03-27 15:02:04 +01:00
hack-it-and-try-it-yourself.md howto llm test 2025-03-27 15:02:04 +01:00
IMG_20200605_142311.jpg init 2023-11-12 21:43:05 +01:00
index.astro howto llm test 2025-03-27 15:02:04 +01:00
index.mdx we sucht der findet :) 2025-03-28 16:31:37 +01:00
measure-the-plastic-sheet.md howto llm test 2025-03-27 15:02:04 +01:00
post-production-and-show-case.md howto llm test 2025-03-27 15:02:04 +01:00
references.md latest :) 2025-04-08 12:54:38 +02:00
resources.md latest :) 2025-04-08 12:54:38 +02:00
secure-sheet-.md howto llm test 2025-03-27 15:02:04 +01:00
title: Cut out shapes out of plastic sheets with a CNC slug: cut-out-shapes-out-of-plastic-sheets-with-a-cnc- description: In this how to, I will show you our process to cut HDPE Sheets using a X-Carve CNC. Here is the full video in spanish with subtitles https://www.youtube.com/watch?v=4LrrFz802To tags: ["HDPE"] category: uncategorized difficulty: Medium time: < 5 hours keywords: location: Mexico City, Mexico
Cut out shapes out of plastic sheets with a CNC In this how to, I will show you our process to cut HDPE Sheets using a X-Carve CNC.
User Location: Mexico City, Mexico
Step 1: Measure the plastic sheet
For this step we need to measure our plastic sheet: Height, Width and Thickness. Our X-Carve machine works with the CAM Software EASEL, for me, the easiest software for CNC milling out there.
The cool thing about Easel (easel.inventables.com: easel.inventables.com/) is that you can "simulate" your actual material and THEY EVEN HAVE HDPE 2-Colors in their cutting material lists!!
Step 2: Secure sheet
Using the CNC clamps from the X-Carve, secure the sheet to the table,
Step 3: Choosing a file to cut
Now we go to our illustrator, such as Inkscape to design a vector file or download and open source one frome thenounproject.com: thenounproject.com
We download the SVG file, which is an open source vector format and import it to Easel.
Step 4: Follow the cutting Wizzard
Now with the file we can choose the width we want to carve/cut and then we go to cut and start the wizzard:
  • We check that the sheet is fixed.
  • We also specify the cutting bit, we are using a 1/8 flat flute bit.
  • We tell the machine where the coordinate 0-0 is, which we always choose as the down left corner.
  • We raise the bit, turn on the CNC Router!!!
AND PUM THE MAGIC BEGINS!!
Step 5: Post-production and show case
You take now your glasses or object and postprocess them and of course show it to your friends, family and so on.
Step 6: Hack it and try it yourself
You can try this project with other types of CNC machines, even manual Routers or manual saw, as I did on this video: youtu.be: youtu.be/gxkcffQD3eQ, but the important thing is that you share what you do and help this community to grow!!!
Share your ideas and comments!
