machines/howtos/stamp-products-fast-without-heating
1.jpg init 2023-11-12 21:43:05 +01:00
2.jpg init 2023-11-12 21:43:05 +01:00
3.jpg init 2023-11-12 21:43:05 +01:00
4.jpg init 2023-11-12 21:43:05 +01:00
5.jpg init 2023-11-12 21:43:05 +01:00
6.jpg init 2023-11-12 21:43:05 +01:00
7.jpg init 2023-11-12 21:43:05 +01:00
8.jpg init 2023-11-12 21:43:05 +01:00
9.jpg init 2023-11-12 21:43:05 +01:00
10.jpg init 2023-11-12 21:43:05 +01:00
index.mdx howtos: 1st pass 2/3 2025-03-29 07:50:17 +01:00
references.md howtos: 1st pass 2/3 2025-03-29 07:50:17 +01:00
resources.md howtos: 1st pass 2/3 2025-03-29 07:50:17 +01:00
Stamp products fast. Without heating stamp-products-fast-without-heating We will show you how you can stamp the products you made in a fast efficient way. The main benefit is that it doesnt require heating so you have no heatup/cooldown times. This is good for bigger productions and just saves energy :)
PP
product
Guides Easy < 1 week Chennai, India
Stamp products fast. Without heating We will show you how you can stamp the products you made in a fast efficient way. The main benefit is that it doesnt require heating so you have no heatup/cooldown times. This is good for bigger productions and just saves energy :)
User Location: Chennai, India
Step 1: Get a product
First you need to have a product. We work with sheets and cut them with CNC to make products. We only tried this technique with PP and HDPE. So lets met show you how we stamp them.
Step 2: Make your stamp
Make a design for your stamp and mill it in metal. We made ours from brass, but I guess other metals would work as well. Tip: make sure to mirror your design
Step 3: Press
For pressing we like to use arbor press. It works fast and are easy to use/find. Put the product underneath apply some fore and take it out. You can get really fast here
Step 4: Use mould for alignment
We like it when things are consistent. So we use a little mould to put in our product to make sure we always stamp in the same place. This actually also makes sure the product doesnt move when applying force. Not a must, but would highly recommend
Step 5: Ready!
Here you can see a few products we stamped. We made one stamp for our logo and one for the type of plastic. Have fun making yours! :)
