machines/howtos/make-an-adaptable-sorting-system/README.md
2025-03-28 16:31:37 +01:00
4.0 KiB
Make an adaptable sorting system make-an-adaptable-sorting-system Create an adaptable sorting system. Easily move tabs to accommodate different amounts of materials as required.
collection
sorting
Guides Easy < 1 week sorting system, adaptable system, CNC cutting, laser cutting, material thickness, panel alignment, divider panels, smooth surface finish, efficient organization, Lisbon Portugal Lisbon, Portugal
Make an adaptable sorting system Create an adaptable sorting system. Easily move tabs to accommodate different amounts of materials as required.
User Location: Lisbon, Portugal
Step 1: Cuting the panels- CNC machine
Send the provided files to be cut using a CNC or laser cutting machine. Note that the files are designed for a material thickness of 25 mm (1 inch); adjust the files if you alter this measurement. While we only cut the outline on the machine, you can also use it for bevels and engraving.
Step 2: Plastic type- LaserCut
After cutting all panels, use the numbered files to laser cut each one. Ensure proper alignment, especially from the topmost corner, as each divider panel is numbered on both sides.
Step 3: Cuting and Finishing
In this step, cut the front, bottom, and back panels. Additionally, begin finishing and sanding all parts for a smooth surface.
Step 4: Mounting all the pieces
After sanding, assemble using screws. Attach the sides and bottom, then fit the dividers as needed.
Step 5: ALL DONE!!
Organize Plastic Efficiently
You can now sort your plastic more effectively.
To create an adaptable sorting system with movable tabs, the following tools, software, and materials are required based on the tutorial. Each category is organized below for clarity.
  • CNC or laser cutting machine (common suppliers in Lisbon)
  • Laser engraving/cutting machine (for numbered panels)
  • Screwdriver or power drill (for assembly)
  • CAD software (e.g., AutoCAD, Fusion 360) to adjust file thickness
  • Vector design tools (e.g., Adobe Illustrator, Inkscape) for file editing
Materials
  • 25 mm thick sheets (wood, acrylic, or MDF)
  • Screws (size matching panel thickness)
Additional Tools
  • Sandpaper or power sander (for finishing surfaces)
  • Clamps or alignment jigs (for precise assembly)
  • Measuring tape or calipers (to verify dimensions)
The process requires precise adjustments in design software for material thickness and proper machine calibration when cutting or engraving numbered dividers [1].
Based on the provided information, there are no references or sources included in the text to process. The content describes a fabrication process for creating a sorting system but does not cite any external articles, books, papers, or other resources that could be listed as references. Without specific sources mentioned or provided in search results, it's not possible to generate a grouped reference list.
