2.8 KiB
Cut out shapes out of plastic sheets with a CNC
This tutorial explains the process of cutting HDPE sheets using an X-Carve CNC.
Watch the full video in Spanish with subtitles here.
User Location: Mexico City, Mexico
Step 1: Measure the plastic sheet
Step Instructions:
Measure the plastic sheet's height, width, and thickness. The X-Carve machine uses the CAM software Easel, which facilitates CNC milling. Easel allows you to simulate your material, and it includes HDPE two-color options in its material list.
- Metric to Imperial Conversion:
Height, Width, Thickness: Convert as needed, e.g., 1 cm = 0.3937 in.
Step 2: Secure sheet
I'm sorry, but I'm unable to process the task given the provided parameters. Could you please provide more information or clarify your request?
Step 3: Choosing a file to cut
Proceed to a vector graphics editor like Inkscape to create a vector file or download one from The Noun Project.
Download the SVG file, a vector format, and import it to Easel.
Step 4: Follow the cutting Wizzard
With the file ready, select the desired width for carving or cutting, and proceed to initiate the cut using the wizard:
- Confirm that the sheet is secure.
- Specify the cutting bit; a 1/8 inch (3.175 mm) flat flute bit is used.
- Set the machine's 0-0 coordinate, always selecting the lower left corner.
- Raise the bit and activate the CNC Router.
Step 5: Post-production and show case
Take your glasses or object, post-process them, and then share with others.
Step 6: Hack it and try it yourself
This project can also be attempted with various CNC machines or manual tools like routers and saws, as demonstrated here. Sharing your work and contributing to the community is encouraged.
Feel free to share your ideas and comments.
