machines/howtos/easily-hands-free-connect-moulds-to-the-injector/README.md
6.7 KiB
Raw Blame History
title: Easily (hands-free) connect moulds to the injector slug: easily-hands-free-connect-moulds-to-the-injector description: ### Methods for Attaching Molds to Injectors Traditional methods like screw-on molds, clamping beds, and car jacks often require significant manual effort and time to attach molds to injectors. A motorcycle stand offers a more efficient solution, providing sufficient range to clamp the mold against the injector while enabling the use of leg strength, thus keeping hands free. This method facilitates the easy lifting of heavier molds and accessories such as clamps, potentially minimizing the need for extensive bolting during clamping. This approach is compatible with conical injection nozzles and chamfered molds. The equipment referenced in this guide is from PlasticPreneur. tags: ["hack","product","untagged","injection"] category: Guides difficulty: Easy time: < 1 hour keywords: mold attachment methods, motorcycle stand for mold clamping, injector mold setup, conical injection nozzles, chamfered molds, PlasticPreneur equipment, DIY injection mold stand, wooden block elevation, tufftuff jack usage, ergonomic mold setup location: Lancaster, United Kingdom of Great Britain and Northern Ireland (the)
User Location: Lancaster, United Kingdom of Great Britain and Northern Ireland (the)
Step 1: One video to explain it all...
Refer to the attached video for a detailed explanation of the process and required components.
Step 2: Find yourself a bike stand
We acquired our first stand from Facebook Marketplace. Consider checking bike workshops for old stands. Alternatively, search online for "motorcycle stand" or "dirtbike stand" to find one easily.
Step 3: (if wall-mounted) Make it taller
Four pieces of 3x2 wood (7.6 cm x 5.1 cm) are used at each corner of the stand's flat plate, topped with an additional flat wood piece to elevate the mould bed. Metal or alternative shapes can be considered if preferred. The gap between the pillars serves as storage for height-raising blocks.
If sufficient height is not present, wooden blocks can be added for elevation when using a floor-based injection moulder.
Alternatively, shorten the pillars and add a tufftuff jack on top, eliminating the need for variable thickness wooden blocks. The tufftuff jack, with a plate, adjusts the general working height, while a bike stand provides additional travel to align with the nozzle.
Step 4: Modify the lever system
Initially, the lever is set at a height that may be challenging for frequent use. While this position offers a good workout, we opted for an easier adjustment. By reversing the arm that attaches to the lever, we achieved better functionality.
We added a new hole in the rod emerging from the base and corresponding holes in the arm. This allowed us to secure the arm with an M8 bolt, ensuring stability. An additional bolt was placed behind the arm to prevent excessive backward pivot, ensuring secure use.
Feel free to design an alternative system that might offer improved ergonomics or aesthetics. Be inventive!
Step 5: Watch the video
For a comprehensive explanation, please watch the video.
Construction Components
  • Motorcycle stand (example source)
  • Four 3x2 wooden pieces (7.6 cm × 5.1 cm)
  • Flat wood piece (for elevating mold bed)
  • M8 bolts (secures arm adjustments) [Video]
  • Wooden blocks (for height adjustments)
Alternative Options
  • Tufftuff jack with plate (adjusts working height) [Video]
  • Metal plates/shapes (wood alternative)
  • Bike/dirtbike stand (online search)
  • Clamps (minimizes bolting needs) [Video]
  • Conical nozzles/chamfered molds (compatibility noted) [Video]
Useful References
Books
Papers
YouTube
OpenSource Designs
