machines/howtos/make-your-shelf
1.jpg init 2023-11-12 21:43:05 +01:00
3.jpg init 2023-11-12 21:43:05 +01:00
base.jpg init 2023-11-12 21:43:05 +01:00
estructura2.jpg init 2023-11-12 21:43:05 +01:00
estructura.jpg init 2023-11-12 21:43:05 +01:00
extrusora.jpg init 2023-11-12 21:43:05 +01:00
hole.jpg init 2023-11-12 21:43:05 +01:00
index.astro lovebot was here :) 2025-03-28 07:15:54 +01:00
index.mdx tests:filter/model - validate link cache 2025-03-28 14:32:35 +01:00
menor-2.jpg init 2023-11-12 21:43:05 +01:00
references.md Dave's Cash Cow 2025-03-29 13:52:35 +01:00
resources.md we sucht der findet :) 2025-03-28 17:08:49 +01:00
tamano.jpg howto assets: normalized 2025-03-23 10:47:33 +01:00
tamao.jpg init 2023-11-12 21:43:05 +01:00
viga.jpg init 2023-11-12 21:43:05 +01:00
Make your shelf make-your-shelf Learn to build shelves or small furniture using the extruder and the injection machine.
mould
PP
extrusion
Products Medium < 1 day San Javier, Spain
Make your shelf
Make your shelf Learn to build shelves or small furniture using the extruder and the injection machine.
User Location: San Javier, Spain
Step 1: Make the beam
We will use a square tube 2cm in diameter and 40cm long. You don't need to screw it in, you can hold it carefully not to burn yourself by hand.
Step 2: Cut and drill holes
For this model we have used:
  • 35.5cm x 3
  • 19,5cm x 2
  • 14cm x 2
  • 18cm x 2
Feel free to make your modifications if you need it bigger or smaller.
Step 3: Assemble the base
Using the mold for the injection machine with a square shape and measures of 14cm x 14cm. We will make 8 units that we can easily glue or screw.
If you liked it, you can follow our project and see all our products at www.menorplastic.com
Thanks for your support 😊
