2.1 KiB
Make a Pee Pee Urinal
I am a flat pack design utility add on to the streets. The urinal is a quick solution to the need of urinal at parks and streets spots that has become a urinating spot,
In the attached folder you will find:
3D File (.skp)
Laser cut files (.dxf)
Blueprints (.pdf)
Manual
Step 1: DownTake sheet of 12mm thickness
Take sheet of 12mm thickness The sheet has to be of 12mm for the exact grooving composition, 2 sheets of size 4ftx 4ft. If your sheet thickness varies then 12mm please adjust the grooves in cad file
Step 2: Get cad file in CNC machine
The cad file is supposed to be converted in cnc machine file format and let the machine do its job, The file can be accessed in auto CAD or CDR. The metric systemm of file is Feet and Inches.
Step 3: Buff the edges
Next step is to clean the edges and buff it for further smoothness, The grooves are to be maintained the same sizes mentioned in the manual through out
Step 4: Assemble the product
Assemble the product as mentioned in the following document. It may take 2-3 people to assemble the product because the sheets are delicate and often intent to break at corners if not handled properly.
