machines/howtos/modular-interconnecting-formwork/README.md
2025-03-29 13:52:35 +01:00
10 KiB
title: Modular Interconnecting Formwork slug: modular-interconnecting-formwork description: ### Tutorial on Using Plastic Bricks for Concrete Formwork This guide outlines the general process of using plastic bricks to construct a concrete formwork. Formwork acts as a mold for poured materials, and in this method, the bricks serve as a detachable and reusable tool for creating these forms. tags: ["compression","HDPE","hack","product"] category: Moulds difficulty: Very Hard time: < 1 week keywords: plastic bricks, concrete formwork, construction guide, concrete pouring, reusable formwork, formwork assembly, concrete molding, construction materials, safety gear construction, DIY concrete formwork location: Melbourne, Australia
User Location: Melbourne, Australia
Step 1: Understanding formwork as a mould for construction
Formwork is used to create frames for pouring concrete, rammed earth, or other materials in construction. Traditionally made from wood, they can also be crafted from plastic.
We advise beginning with small projects to understand the process, iterating and expanding your ideas. Costs may vary considerably based on your project.
Current brick designs, paired with thin sheets produced by a sheet press, enable formworking. Detailed drawings for an optimized brick mold can be found via the provided link, with machining instructions to follow.
Step 2: Tools, skills & materials required
Equipment and Skills Needed
  • Hearing and eye protection
  • Safety boots
  • Dust mask
  • Power tool operation skills, particularly with drills
  • Safety induction in construction for your area
  • Experience in mixing and pouring concrete
Materials Required
  • Bricks for formwork
  • Cement, sand, and aggregate
  • Building design drawings
  • Impact driver and drill
  • Masonry drill bits (optional masonry drill)
  • Self-tapping timber screws
  • Reinforcing bar (rebar)*
  • Rebar ties and tie tool
  • Starter bars with safety caps
  • Anchoring adhesive and application gun
  • Concrete mixer and plastic tubs
  • Shovels for concrete
  • Steel brackets**
  • Concrete vibrator
  • Trowel
  • Hot glue gun and glue sticks
  • Stringline, chalk, or construction spray paint
  • Tape measure
  • Wire brush
* To cut rebar, a reciprocating saw or grinder is recommended.
** Secure steel brackets using timber screws, formwork stakes, or powder-actuated fasteners.
Step 3: Mark out your wall
To mark where your wall will be built, use chalk, stringline, or spray paint and a diagram of your structure. We used green paint for marking.
Step 4: Install starter bars & rebar
Drill holes in the slab to the depth specified by your anchoring adhesive. Clear the holes of concrete dust. Inject the adhesive, then install starter bars, following adhesive instructions carefully. Wait up to 24 hours for the adhesive to set, and cover unattended starter bars with safety caps.
If necessary, install additional rebar using rebar ties and a rebar tie tool.
Step 5: Erect initial form
Following the outline marked in step #5, lay bricks in rows. For large seams between bricks, fill with hot glue while assembling the formwork. Use a trowel and a pipe to clean the glue in the seams. Alternatively, cover the bricks with a thin sheet, which can be taped to the bricks. It does not need to be strongly secured, as the concrete will press it against the bricks when poured.
Step 6: Secure and brace form
Installation methods will vary based on your site, but consider small steel brackets for securing formwork. Attach brackets to either timber or concrete slabs. This setup prevents formwork from lifting and stabilizes bricks against outward pressure from poured concrete.
Ensure each ground-level brick is supported from behind on the concrete-facing side. Secure at least every third brick to the ground to prevent uplift. Bricks in the top row should be linked to neighboring bricks, as these rows lack the interlocking support provided by other positions.
Alternatives to steel brackets include using simple chocks placed against the concrete-facing surface.
Step 7: Prepare to pour
Before pouring concrete, inspect your formwork for potential issues. Improperly secured bricks, large seams, and misalignment can lead to failure. Concrete blowouts are dangerous and difficult to stop due to the mass of the material.
Once your formwork is secure, arrange your concrete mixer and ingredients for easy pouring. Ensure you have sufficient time to complete the pour before beginning.
Step 8: Begin pouring
To begin, mix enough concrete to construct around 0.8-1.6 inches (20-40mm) of your wall. Place it into the formwork, ensuring it reaches the corners. Check the outer side of the formwork for any concrete leakage at the bottom. Mix and pour slowly, monitoring the base of your form until you reach approximately 6 inches (150mm) above ground level. At this stage, you have overcome the initial major challenge. Allow the poured concrete to set for 90 minutes to support the weight of additional pours, minimizing the risk of a blowout.
Step 9: Complete your pour
Once the initial concrete pour begins to harden, increase the frequency of subsequent pours. Continuously inspect the formwork as the height increases. In our instance, we poured approximately 60 liters (15.85 gallons) of concrete every 30 minutes after the initial section, ensuring air pockets were vibrated out. Using rapid-set cement could allow for a faster pace, but this is not recommended for beginners as it might set before proper vibration or complicate repairs in the event of a mishap.
Upon reaching the top of the formwork, use a trowel to smooth the surface. Edging tools can be used to create bevels on the wall's corners.
Step 10: Demould!
Once the concrete becomes a lighter grey, it is nearing readiness for formwork removal. We waited 36 hours to ensure it was sufficiently set, but consult the cement manufacturer's specifications and consider ambient temperature, as this affects setting speed. When uncertain, allow more time before proceeding.
To demold, begin by undoing fasteners on the top layer and remove the bracing. Bricks can be removed by gently rocking them to lift them off the underlying teeth. Hot glue, if used, will break off easily.
Step 11: Cleanup
In some cases, seams may not be adequately filled with hot glue, allowing concrete to seep in. To prevent this, clean the bricks immediately after demoulding, as the concrete will still be weak and crumbly. Wear safety glasses and use a wire brush for cleaning.
If you've made holes in your bricks, fill them with a hot glue gun using the same plastic you used for the bricks. It's advisable to do this on-site to avoid forgetting to check for cavities later.
Maintain a tidy construction site, as leftover hazards can affect future work. Clean your tools and materials after finishing.
Additionally, remember any important tasks relevant to your situation.
  • Concrete mixer
  • Hot glue gun
  • Concrete vibrator
  • Trowel
  • Plastic bricks (design details)
  • Steel brackets
Safety equipment (eye/hearing protection, boots, dust mask) and additional tools like shovels or tape measures are also required but omitted here for brevity.
Books
Papers
YouTube
Opensource Designs
  • Modular Interconnecting Formwork - [filtered]
