machines/howtos/make-a-squat-stool/README.md
1.6 KiB
title: Make a Squat Stool slug: make-a-squat-stool description: I am a flat pack design utility add on to existing toilets using english WC's to heal correcting the posture which improves the internal architecture of human body and heals many of stomach related disfunctions, improves the digestion system. Me realized in the young generation of today's to correct the posture of using WC the way it was suppose tags: ["mould","HDPE","compression","starterkit"] category: Products difficulty: Easy time: < 1 hour keywords: location: Delhi, India
Make a Squat Stool
Make a Squat Stool I am a flat pack design utility add on to existing toilets using english WC's to heal correcting the posture which improves the internal architecture of human body and heals many of stomach related disfunctions, improves the digestion system. Me realized in the young generation of today's to correct the posture of using WC the way it was suppose
User Location: Delhi, India
Step 1: Take sheet of 12mm thickness
The sheet has to be of 12mm for the exact grooving composition, and size can be of 4ftx 4ft. If your sheet thickness varies then 12mm please adjust the grooves in cad file
Step 2: Get cad file in CNC machine
The cad file is supposed to be converted in cnc machine file format and let the machine do its job,
Step 3: Buff the edges
Buff the edges for a cleaner finish
Step 4: Assemble the product
assemble the product as mentioned in the following document.
