1.8 KiB
| Make notepad covers & springs | make-notepad-covers--springs | How to make small sheets and springs to assemble a notepad |
Products | Easy | < 1 hour | Neuquen, Argentina |
User Location: Neuquen, Argentina
Step 1: Prepare your mix
Select, weight, and mix the colors you want, we used PP shredded bottle caps.
Step 2: Make the springs
Fill the injection machine and wait for the plastic to start flowing, with a small nozzle and a constant weight applied on the machine, use a wooden rod to "screw" the filament around it, make it as long as you want, we recommend using a wooden rod because the plastics sort of sticks and makes it easier to form the spring.
Step 3: Make the covers
Remove the small nozzle from the injection machine and extrude some plastic on a flat sheet, press it against another sheet in a press, wait for it to cool and remove the plastic sheet, cut it to shape, make the holes and assemble the notebook.
Step 4: Enjoy your recycled booklet
Try different combinations, you can make the springs out of the same mixture of however you want :)
