1.4 KiB
1.4 KiB
| title | slug | description | tags | category | difficulty | time | keywords | location | ||||
| Make your shelf | make-your-shelf | Learn to build shelves or small furniture using the extruder and the injection machine. |
Products | Medium | < 1 day | San Javier, Spain |
Make your shelf
User Location: San Javier, Spain
Step 1: Make the beam
We will use a square tube 2cm in diameter and 40cm long. You don't need to screw it in, you can hold it carefully not to burn yourself by hand.
Step 2: Cut and drill holes
For this model we have used:
- 35.5cm x 3
- 19,5cm x 2
- 14cm x 2
- 18cm x 2
Feel free to make your modifications if you need it bigger or smaller.
Step 3: Assemble the base
Using the mold for the injection machine with a square shape and measures of 14cm x 14cm. We will make 8 units that we can easily glue or screw.
If you liked it, you can follow our project and see all our products at www.menorplastic.com
Thanks for your support 😊
